mattg251
Hi everyone,
when i purchased my first merc about 4 month ago little did i realise how much work it really needed to get it back to a good standard. so far i have replaced exhaust, reconditioned all for brake calipers, had the interior striped out and cleaned, repaired the electrics, sorted out some mechanical bits. the list just goes on and on. items left to fix or replace
suroof
window regsfront and back windscreans due to frosting
power antena
welding inner wing
varioius internal trims
external paintwork
front suspension
etc.
etc.
when do you say enough is enough....?
regarding the front suspension, i have recently replaced the o/s/f bottom arm due to the previous owner kerbing it badly with destroyed the alloy.
now changed the wheel sits as it should in the arch but the car is alot lower on that side? i had a real good look around whilst i was changing it, and could not see any signs of damage to the damper or surounding area no sign of leakage. i presume it could be the damper but would like someone elses view on it befor more money gets thrown at it
thanks in advance
suroof
power antena
welding inner wing
external paintwork
front suspension
etc.
etc.
thanks in advance
