W124 throttle travel.
marty359
The Fens
BMW 330d with indicators and Jeep Renegade also with indicators
Ive bought a W124 to use over winter. Everything seems ok but what I have noticed is the throttle has waaaaay too much play in it before the car moves.....is the excessive travel a W124 'thing' or can the biting point be easily adjusted somewhere?
bolide
Brighton
BMW E39 525 Diesel Touring
Adjust the throttle cable & kickdown cable and the car will be much nicer to drive. The adjusters are at the end of the cables on the linkage
Some cars do suffer from sticky throttle operation as well - lubricating the linkage and replacing the throttle cable can help
Nick Froome
the independent Mercedes Estate specialists
WDB124066
1996 E320 Sportline Cabriolet x 2
If the car has ASR be careful not to pull on the throttle cable end to rev the car, and make sure at least some gap/slack is maintained, otherwise it will go into limp home mode.
brigadier
London
500E
It can be adjusted, but you must hear a click when accelerator is fully released near throttle linkage - the throttle off switch. That's there for engine management and gearbox to know you released throttle.
OP
OP
marty359
marty359
The Fens
Thanks chaps, I had a fiddle with the adjuster today its not perfect but its better. I might just replace the cable anyway.
