Sorry to hear about the misfortune. What damage did it cause to your c250td?
I'm planning on using svo mixed with diesel at a 50/50 mix initially. I will gradually lower the percentage of diesel. Hoping to start using wvo next year in the summer. I am planning on filtering my own, but it would help to have a contact of filtered wvo if know of any?
Hi
dont bother with the 50/50 mix - these cars run and on 100% all the time, if the glowplugs are all working. You'll need 10% petrol in the mix over winter to aid starting in the cold. The car may run a bit rough until it heats up but no biggie vs the cost of diesel.
if the filters are blocking it will feel like its about to run out of fuel, and then the car will conk out. After say 500 miles on veg, i would replace all the filters, the intank filter can just be cleaned.
the WVO needs to be filtered down to 5 micron or less to get trouble free running. I'd be very wary of buying any WVO not filtered by myself - too risky and better to buy SVO new. You wont know how much its been filtered down to and whether its been de-watered or whats been added to it (chemical etc). If its not been filtered enough you'll be replacing filters all the time, 500 miles and less.
As before, the veg forum is by far the best place to get advice. I'm there too under the same username
i would also add - you WILL get blocked filters at the roadside when running veg oil, so you need to be prepared and have the tools in the car. make sure the 1st time you need to do it isnt on the hard shoulder..... replace on the drive 1st, even if they might not need replacing.
ECP is the cheapest for filters, keep an eye out for the discounts.
Also running WVO or SVO is a 'DIY "hobby"'.... if you cant fix your own car, ie replace fuel pipes, meddle with filters, replace glowplugs then the cost of garage fees will outweigh the fuel savings, so you need to be able to do it yourself, otherwise no point.
