W124 vibration noise - advice please
Discussion in 'General Discussion' started by The Boss, Jun 8, 2011.
  1. The Boss
    The Boss Hardcore MB Enthusiast
    3,524
    Dec 10, 2008
    private!
    Car:
    private!
    Hi guys.
    on my 124 cabrio, i took it out of the garage today and was confronted by a vibration noise.
    here are the symptoms, and if anyone can advise it would be appreciated.
    1. on start, and in park, there is no vibration noise.
    2. in neutral, there is also no noise.
    3. when in reverse or d, there is a vibration noise, sounds like a screw in a can shaking.
    4. as you drive, the noise continues..
    this noise appears to be coming around or beneath the drivers side footwell.
    5. when accelerating and driving, the car develops what can only be described as a gurgling sound, that to me is coming from the front drivers side, around the top corner of the dashboard, but it could be engine bay.
    any help or advice appreciated
  2. Sp!ke
    Sp!ke Administrator Staff Member
    12,234
    Jun 2, 2002
    West London
    Car:
    SL500 & The Fart Car
    It sounds like this might be two separate noises/symptoms.
    The gurgling (from your brief description) could be coolant slooshing round your heater matrix like there is air in the system. Have you checked your coolent levels recently?
    The second noise I'm slightly less sure of without a better description of the noise but the screw in a can reference reminded me of a noise that I had which turned out to be an engine mount that was shot.
    These are fluid filled and have a small bearing inside that can rattle in a really irritating way when worn. I bought a mechanics stethoscope and pinpointed mine in a matter of minutes. For a £5 investment, its a nifty tool to have in your toolbox.
    1 person likes this.
  3. grober
    grober MB Club Veteran
    25,254
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    The tin can noise could easily be exhaust body heat shields or -more likely- the down pipe external heat shields- they are crimped on to the main pipes and eventually they corrode allowing them to rattle at certain resonant frequencies. Can be cured in the short term with the judicious use of jubilee clips. The gurgling as SPIKE said is associated with your heater water circulation. Possibly air in the coolant or the small circulation pump may have failed
  4. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
    Small circulation pump - thats a new one on me.
    Where might that be on a W124?
  5. Dee-124CAB
    Dee-124CAB Hardcore MB Enthusiast
    1,398
    Jun 15, 2007
    West London
    Car:
    Mercs Mercs Mercs....
    Tin noise defo sounds like exhaust down pipe heat shields....
  6. grober
    25,254
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Its item 140 on this diagram [hidden by the airfilter box/washer bottle] but sometimes its integral [vertically positioned] with the duo valve assembly nearer the bulkhead. pic inc
  7. Ade B
    Ade B Hardcore MB Enthusiast
    1,832
    Nov 26, 2006
    South London
    Car:
    2006 Accord Tourer iCDTI EX
    Engine/gearbox mounts shot meaning when under load the drive train is twisting and causing something to touch the exhaust heat shields perhaps. Had a similar issue with mine although less rattly - Mr Froome reckoned it was the above.
    Ade
  8. carat 3.6
    carat 3.6 Hardcore MB Enthusiast
    3,923
    May 11, 2011
    Buckinghamshire, yuppie central 1985.
    Car:
    96 e300d, 88 w124 superturbodiesel, 90 bmw E30 v8, + "others"
    Exhaust heat sheilds or perhaps a rattling catalic convertor?
  9. A210AMG
    A210AMG MB Club Veteran
    8,475
    Mar 15, 2007
    England
    You need to use it more :)
    Cars don't like being stood.
  10. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
    n
    interesting....so the purpose of this pump is just to ensure circulation to the heater matrix then?
    (wondering if this could be linked to my somewhat intermittent heating on my w201)
  11. grober
    25,254
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Don't think the 190s had this pump afaik - different control system too-- vacuum operated heater valve for example
  12. OP
    OP
    The Boss
    3,524
    Dec 10, 2008
    private!
    Car:
    private!
    my mechanic down the road put it on the ramp and suggested two things..
    he could not hear the rattle outside easily, but could hear it inside..
    he suggested it could be engine mount or the torque converter in the gearbox.
    Any thoughts on this?
  13. dinoy
    dinoy Hardcore MB Enthusiast
    1,999
    Feb 15, 2010
    london
    Car:
    mercedes of course
    what about the drive shift gaters connecting gearbox to the driveshaft do not exact name, in my w124 estate it vibrate on sudden quick kickdown from idle!!
  14. grober
    25,254
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Expensive thoughts? What did the exhaust downpipe heatshields look like especially at the end crimps where they wear/rust away?
  15. grober
    25,254
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    duplicate post sorry
  16. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
    Doesnt sound like he has the right tools to find the source of the noise.
    I can recommend someone reasonably local to you (Brentford) that does if you want.
    Mind you, you could start with the engine mounts anyway I guess, as if they've never been done they probably need changing anyway. Likelihood is they are the source of the noise too imho.
  17. OP
    OP
    The Boss
    3,524
    Dec 10, 2008
    private!
    Car:
    private!
    Id appreciate that :) - PM me please
  18. neilz
    neilz Hardcore MB Enthusiast
    1,534
    Nov 14, 2009
    London
    Car:
    W140 S320L, 1997, Black with Black Bird's Eye Maple trim
    Sorry to bump this but if you haven't had this resolved I have the same tin-rattly sound and the heat shields on my downpipe are completely corroded, in a terrible state, and I am pretty sure that could be the cause of your rattling.
    If you have had this resolved, was it that?
  19. Mr Nicey
    Mr Nicey Hardcore MB Enthusiast
    131
    Feb 8, 2011
    Surrey
    Car:
    SL320 V6
    :DIts the sound of depreciation.. Dont fret you have along way to go yet ;-)
    2 people like this.
  20. OP
    OP
    The Boss
    3,524
    Dec 10, 2008
    private!
    Car:
    private!
    havent noticed it, as havent actually used her since i started the thread till i took her out of the garage..
    i presume it is still there, but will have to check when i take her for a drive..
    do u happen to live near London? or do you have a video that could be taken of the sound to see if it is the same sound?
Share This Page
