Vectrolosys
Hello,
I have had an annoying waterleak that I tried to trace today. Basically, my footwells would fill with water (not horrendously) just a small bit in the bottom, sort of in the middle.
Today, I decided to see if I could find the source of the problem.
1 - I removed the battery
2 - I unblocked the drain on the passenger side of the car, going into the inner wing area.
3 - I cleared some leaves from under the heater unit.
4 - I poured hosed down both sides, the windscreen seals and into the central drain area. Each time, water poured out from the correct places and the carpet areas stayed bone dry.
5 - I thoroughly sprayed the door seals, again, bone dry.
6 - I opened the sunroof and poured a jug of water down each drain channel.
At this point, I put all the carpets, centre panels etc back in and called it a day.
My question, it's obviously not the drains. If the heater air intake vents took in water, would water drain out the heater unit, or would it collect and pour in through the floor vents, which run under the carpet and look like they could dump their contents in about the right place?
Thanks in advance,
James
Thanks in advance,
James
