Rose Chap
I’d like to pick the brains of the knowledgeable types on here about a particular problem with the AC on my W126 300SE.
A few weeks ago a horrible noise started from under the bonnet. Subsequent investigation by a mechanic revealed this to be a faulty AC compressor, so this was removed and a shorter belt installed so the car ran as normal – just without AC. A replacement compressor was ordered, though this didn’t fit the mounting position available.
Even more further investigation revealed that whilst my 300SE had AC from new, it had at some point since being built in 1989 and my buying it in May, the AC compressor had been replaced with one compatible with R134a, but the compressor in question was not an OEM part, and to make it fit had been mounted onto a bracket. Attempts to source a direct replacement AC compressor have not been successful – apparently the unit isn’t made any more.
Once this was figured out, my tame mechanic found that the bracket holding the AC compressor was removable, leaving holes in the engine casing(? – not sure if my terminology is right here but hopefully you understand my point) that presumably the ‘proper’ (Mercedes) AC compressor would bolt into.
Unfortunately, there is confusion about what AC compressor should go on. Would one from a W124 300E work? Does it have to be from a W126? Is it the engine that dictates the AC compressor? The model year? I’ve seen a few available second hand and from spare parts websites, but I don’t want to order the wrong one.
Also, how hard is it to fit the replacement compressor? Hopefully it’s just a case of bolting it on, fitting the right poly V belt, reconnecting the AC pipes and getting it recharged. Am I being hugely naive here or is it really that simple?
All help gratefully received!
RC
RC
