grober
MB Master
Could be several things but ironically your poor starting could be caused by the mixture being too rich. This could be a failure of the thermo -time switch which effectively earths the cold start valve- meaning it doesn't operate normally when the engine is hot. OR it could be a failure of the warm up regulator which controls the mixture strength to the engine depending on engine temperature [ its bolted to the cylinder head] Both units incorporate bimetal springs and in the case of the regulator a flexible diaphram- these units are very robust and reliable but inevitably with time------?? I suggest you go for a run to really heat up the engine and clean up the plugs then when you experience the hot start problem remove a couple of plugs and check for fuel- if they stink of fuel its a mixture/enrichment problem if they are "dry" then fuel supply problem [ FPR etc] Bosch K Jetronic Fuel Injection Manual
