MPG
- Aug 14, 2008
Looking for a bit of help with this one. My handbrake warning light has decided it wants to stay on - it was always a bit sticky in the past and you'd often have to put the handbrake on and off a couple of times to get the light to go off.
I know the fluid level is fine & the pads are good. The handbrake also applies and releases just fine, it just doesn't put the light out. I think its just the release sensor on the mechanism thats gunked up after almost two decades of use!
Does anyone know where the sensor that triggers the dashboard BRAKE light is located ?
