[SOLVED] W126 Radiator top hose leak
Discussion in 'Engine' started by jkeith, Mar 20, 2011.
  1. jkeith
    jkeith Active Member
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    1989 w126 300 se, 1986 3.2 Carrera Sport Coupe
    My BEHR radiator has an anoying weep from the top connector.
    Having just replaced the head gasket and then the water pump to cure water and oil leaks, I wonder if it is all linked to a change in coolant antifreeze.
    The connection appears to have a joint in the horizontal plane and I am wary of trying to open this joint as the only retaining feature seems to be the plastic 'clips'. Too much force would snap these and ruin the radiator.
    Has anyone managed to cure a similar leak without replacing the radiator?
    Is it possible to super glue or plastic weld it with an adhesive?
    Any tips would be appreciated.
  2. grober
    grober MB Club Veteran
    27,625
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    A picture would help?
  3. OP
    OP
    jkeith
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    Hi Graham, the connection is the small pipe that comes out of the top of the near side of the radiator and is connected by a rubber pipe across the top of the radiator to the fill tank on the off side. The leak is where the plastic outlet is connected to a 90 degree plastic elbow.
    I'll take a picture and load it tomorrow.
  4. kth286
    kth286 Hardcore MB Enthusiast
    2,923
    Feb 4, 2003
    Caversham Berks
    Car:
    E320 Coupe
    those plastic elbows are (or at least used) to be available from dealer very cheap.
    1 person likes this.
  5. OP
    OP
    jkeith
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    Thanks, however, the availability of the part is not the issue, I am trying to find out if the elbow can be removed without risk of snapping the fixing clips and if a new seal is an effective repair.
    Hoping to get advice from someone who has solved this problem previously.
  6. OP
    OP
    jkeith
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    This is the connection that is leaking
  7. jonnyboy
    jonnyboy Hardcore MB Enthusiast
    2,562
    Nov 27, 2005
    Camberley, Surrey
    Car:
    1991 sl300-24 project,s124 280,w115 no interior, w108 project no engine
    As long as you are careful it's dead easy - 5 min repair.
    Just make sure you have the new part to hand - do NOT be tempted to have a "play" beforehand unless you like walking... ;)
  8. OP
    OP
    jkeith
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    Sorry to be a pain Jonny, how do I avoid damaging the retaining clips?
    Is it better to warm the engine first?
    How does the elbow come out best?
    Does the coolant level need to be reduced or not?
    Just trying to avaoid a diy ''*ock up!
  9. jonnyboy
    2,562
    Nov 27, 2005
    Camberley, Surrey
    Car:
    To be honest I can't remember as it's been ages since I did one, but I do remember giving her a run then letting it stand a bit to take the heat out of the coolant.
  10. kth286
    2,923
    Feb 4, 2003
    Caversham Berks
    Car:
    E320 Coupe
    I never got round to fitting my spare in the end BUT I read instructions as follows if memory serves:
    1. take big hose off and catch fluid.
    2. insert long nose pliers to squeeze the plastic prongs of elbow and pull elbow out.
    3. insert new elbow by pushing into top hole, and will seat itself automatically.
    2 people like this.
  11. OP
    OP
    jkeith
    79
    Jan 1, 2011
    Jesmond NE2
    Car:
    Got the replacement part, disconnected the large radiator top hose (used a large plastic bag without holes to catch the cooolant) and eased the old elbow out with a pair of pliers and a blunt flat bladed screwdriver. I first soaked a rag in boiling water and warmed the old elbow to make it more pliable. It was still tricky to get it out but the two pronged retaining clips were not the main issue, it was the three legs of the male fitting that needed a healthy amount of force to get it out.
    The old seal was eroded to the extent that it was the same diameter as the elbow. The new fitting was simple to fit and the problem has thankfully disappeared.
  12. jonnyboy
    2,562
    Nov 27, 2005
    Camberley, Surrey
    Car:
    Good job.
Share This Page
