D
Deleted member 11979
Guest
My recently acquired w126 300se is sat too high one the drivers side front corner.
What are the things to check?
It seems unnaturally high so I don’t think it’s that the rest of the car is too low, in fact it all looks a bit higher than it should.
Can rubber spacers be fitted to a w126 as they can on a w124 to adjust ride height?
Would the incorrect spring (from a v8 or diesel) cause a 2 inch variation?
On the passenger side the top of wheel to arch is about 85mm, drivers side about 130mm
Many thanks
Many thanks
