w140 gearbox oil
hagarfriend
Hampshire
CL63 AMG
Hi to you all,
How do i check the oil level on the autobox on my s280 ( w140 i think )
Do i need to have the enginse running?
Many thanks
Clint
Tinkerer
Norfolk
W210 E220 CDi
The dipstick tube is usually at the back of the engine where it joins the gearbox on the drivers side and has a tamperproof top which you have to break the seal on to open it. You may also find that there is no dipstick fitted which means that you either have to buy one or take it to your dealer to check it. The level needs to be checked at running temperature, the temperature levels are usually marked on the stick but you check the level with the engine off.
