yojay
As titled I have a 98' S420 W140 without SLS, and the rear suspension runs too low.
As you might be able to see from the (random, crappy) pictures, the rear has about 1" of clearance between the arch and top of the tyre wall. A couple of MB specialists, PCS, WGMB and Starwerx, have seen the car and agree the rear runs too low.
The car runs an LPG kit with a small, 40l toroidal spare wheel well tank. I suspect this extra weight is contributing to the issue. With rear passengers the car will frequently bottom out over bumps and undulations.
So far I have changed the rear dampers and springs to Bilstein OEM spec which hasn't helped the ride hight. I refreshed the rear tired stock suspension using the following parts:
BLS24-017077 (Bilstein B4 Gas Shock Rear Absorber)
BLS36-129577 (Bilstein B3 Original Equipment Rear Spring)
Also added in the thickest shim (4 notches IIRC).
I've changed the front too (which remains at a normal height), and the comfort and handling have both really improved. However the rear ride hight is exactly the same! :fail
I'm hoping to rectify the sag with some firmer / taller springs. Looking at the MBOC EPC, there are two spring options, the firmer option for cars with lots of OE equipment (rear elec seats, fridge etc) is A1403242104 AFAIK. I don't want to buy the OEM springs from MB because of the cost and the fact that they might not resolve the issue. I also don't have the original springs for part number reference.
What I have seen is both, Lesjofors and Kilen sell a "reinforced" spring for the W140. It doesn't give any further info, just says, "for vehicles without leveling control - Reinforced Version". I'd go for these straight away, they're cheap, but their OEM equivalent number doesn't match anything I've seen in the EPC for my car.
The OEM equivalent number for the Lesjofors reinforced spring is A1403241404. I'm not an EPC pro and haven't managed to reference this number against my car, so I don't know if they will fit / fix the problem?
Long shot - but can anyone shed some light on the Lesjofors spring compatibility or recommend a solution?
Cheers!
Cheers!
