W163 Jerky Throttle at low revs
m11nch
ml270,ml420,ml280
Hi All,
Firstly Thanks for a great site this forum has been a great sea of knowledge in putting my ml270 back to running like it should,
But i am stuck on where to go with this. At low revs the throttle is all over the place it jumps and dips a couple of hundred revs as if i am slightly tapping the accelerator causing a jerky motion in the car if i accelerate it problem goes away ie on a hill but if i just want to keep the same speed and cruise it shows up it happens in all gears but is more noticeable in first as the jerking is more pronounced. I have put it on a cheap obd11 reader and no fault codes came up
any input would be greatly appreciated
