pompeypetey
I do not know about your vac hose - sorry.
A pressure test on your coolant system is cheap and effective, more so than looking for evidence of leaks, to start with. Leaks like this usually only happen when the system is pressurised so any leak is likely to be vaporised coolant and may not be visible to the eye. The other method is to get a luminous/type dye in the coolant then look for evidence of it having sprayed onto the engine or undertray etc. Some Antifreeze does have this in it. Check that it is the correct coolant for your engine. The wrong stuff can cause leaks!!
True, I will get it done it's just a case of waiting for the kit to be available.
It's full of de-ionised water at the moment as I've been flushing it over and over again (It sat drained with the heads off for about 6 months) but I'll fill it with 50/50 G05 this afternoon.
