MOZ
- Sep 3, 2014
- Location
- Knaresborough,North Yorks
- W163 ML270 Inspiration, Leon Cupra TDI
Hi Guy's,
At fear of being slammed for asking another question that gets raised all of the time I apologise in advance (I have done various searches and found lots of useful info on the dreaded black death).
I am currently looking (possibly stupidly- given the horror stories and some peoples advice of Don't do it!!!!) at buying an ML 270 7 seater as a family work horse. I'm looking at a W163 model probably 2004 and will be in the region of 100k miles.
I have done a lot of research and know quite a bit now as to what to look for.
I have found one that I'm pretty interested in, it has already had some of the major common problems sorted (inlet manifold and flap motor replaced, conductor plate for transmission etc.).
I have been to look at it and all looks pretty good (rear springs look good) there is a few slight under paint bubbles in the usual areas (even on a 2004 which allegedly has the galvanised body, although I have seen evidence of this throughout the forum on the full range of galvanised Merc's).
The only doubt I have is that I removed the engine cover to check for the injector seat black death problem and sure enough (pretty much as expected knowing how common it is at this age) there was evidence of 1 injector (#4 counting from the front of the engine) leaking. It wasn't bad and looks like it has been caught early as the area was discoloured but no real build up of any classic black tar. #3 also had some discolouration but it was difficult to tell if this was spread from #4 or if #3 was starting on one side too) the others looked immaculate.
So my question is what sort of costs would I be looking at (assuming it is not too bad) and is a straight forward removal, clean, re-cut of seat, new washer ,bolts ,clamp re insert).
Clearly I will contact a couple of indies to get some pricing locally, but just checking to see what others have paid so I know whether they are taking the mick or not. Clearly if the valves are badly stuck and the job is bigger than expected then I know it will be more, but just wondering what to expect for a straightforward job, so I have an idea as to how much bartering room on the vehicle price I will need to consider.
Thanks and sorry again if I have stepped on any toes regarding dragging up same old same old questions.
Moz
Moz
