W163 ML270 limp home mode
padster1
south west
2000 ml 270
Greetings all.
Hope this finds you all in the best of health and enjoying yourselves, unlike me!
As you've probably guessed my beloved ML is a bit poorly. It's a 2000 model with 150,000 miles on it and has been a reliable workhorse for the past year or so, up until last week. On my way home from work the thing wouldn't rev past 2000 before changing up a gear and was seriously down on power, did manage to get to motorway speeds eventually though, no CEL and my little bluetooth obd dongle and the torque app couldn't pick up any faults either. I had a little look on the forums and the conclusion seemed to be that the MAF needed replacing. Done that and nothing changed! :-(
Next, I borrowed a mates expensive handheld unit and plugged it in, 2 faults caught my eye.
P1470-16 Charge pressure control, Charge pressure is too low.
P1403-32 EGR rate too low.
And I also noticed that when I hit 2000 RPM the MAF readings drop to -2.4 g/s. (not sure how accurate that reading would be as again its through my cheap dongle through my phone.)
Now looking into the codes separately would suggest the EGR valve is on its way out and so is the turbo, Can't seem to find anyone who has had both codes at the same time though, so not too sure on how to proceed. Hopefully, UK November weather permitting, I'll get a chance to have a good look around it at the weekend and see if there are any perished or cracked hoses but other than that I haven't got the faintest idea of where to start without ripping it all apart! Any advice would be much appreciated.
What brand was the MAF and was it a new unit?
It was a new Pierburg, and the readings I get are the same for my old one and the new one.
your codes may be well related, system monitors function of egr by air mass reading change. Then if there is implausibility in air mass/ boost pressure, it triggers either MAF, turbo actuator or egr code. Also simple leak in boost system may trigger those, like you have figured out.
Well now, during a break in the weather I managed to get out for a look. Couldn't really see anything so I came up with the idea of removing the EGR for a good clean. It was caked in crap! After a good clean and fitting a new bolt on the bottom of the EGR as it was missing one from there and taking it for a spin, guess what, the fault was still there. :-(
I then thought I'd have a look at changing the alternator belt as mines looking a little bit worse for where when I decided to have a little look at the vacuum pump at the front. Took of the vacuum connections and gave it a little blow. there was no resistance, the pipe had split where it goes into the actuator! a quick bit of knife work and a burnt arm later and the car is now acting as it should and the MAF isnt giving me that -2.4 reading anymore! I'd almost forgotten how quick it can be! I'm one happy chappy again. :-D
Thanks for you help guys, very much appreciated.
Gold star for persistence! Glad you managed to get it fixed without having to have a wallet transplant
