MOZ
- Sep 3, 2014
- Location
- Knaresborough,North Yorks
- W163 ML270 Inspiration, Leon Cupra TDI
Hi guy's,
Thought I would pass on some info to help someone else in the future.
As seems to be common place on ML270's my thermostat was not working correctly and was either fully or more likely slightly stuck open as my engine was constantly running cool around 60 degC.
Having done a lot of research ans being reasonably mechanically minded, I bought a replacement and had a crack at it last weekend. My research had highlighted a common potential risk of damaging one of the plastic fuel pipes that run very close to the thermostat (which go brittle over time).
Being extremely cautious and methodical I managed to remove the old Thermostat without too much trouble. it is tricky and tight in there (I did remove the Oil filter first) and you do need to maneuver around the fuel pipes.
Unfortunately while fitting the new thermostat during one particularly fiddly bit (aligning a strange double ended bone/mushroom shaped pipe which totally relies on a press fit at both ends- this worried the hell out of me) yes you guessed it, the bottom of the thermostat nudged the fuel pipe and the crappy plastic T piece snapped (as seems to be common during this procedure). Be warned any one trying to change the thermostat - this is a very likely risk.
As I was doing this on Saturday afternoon- clearly MB parts dept had closed, and I needed the car on Sunday.
With this fuel line broken, the car was completely disabled. I didn't have any bits to be able to bodge it so begrudgingly declared defeat and resorted to calling out the AA to see if they had any T pieces and pipe that could repair it.
They didn't have anything to make a permanent repair but did use a short length of rubber hose and a couple of jubilee clips) to cover over the snapped off part (Ignoring the broken T branch that goes off to some bleed type pipe mechanism on top of the engine) and just made a straight Join across the cracked part sealing the line between the low pressure and high pressure pump. This worked a treat and after a fair bit of cranking, the car fired up and runs fine (without the branched off T piece - clearly not needed for the car to run) in fact I'm not entirely sure what this does - maybe someone on here can enlighten me - is it for purging and drawing the fuel through?.
Clearly this is a temporary fix and I have now purchased the correct part - which is a fully moulded 3 piece pipe molded into 1 part ( part number A6120703232 - cost £38 incVat from stealer) which I will hopefully get round to fitting this weekend.
But thought I would share the danger of changing the thermostat with any budding DIYers and also that if the 3rd way does snap off, you don't need to worry about that branch off part for a temporary fix to get you back on the road again, just ignore it and bypass it with a straight through joint temporarily.
Hope this experience helps some others. The thermostat change is a bit fiddly but straight forward apart from the fuel line risk. Engine now runs at its correct 85 to 90 degC, and hopefully a bit more fuel economic
All the best.
Moz
All the best.
Moz
