DexterML
As per the title, I am checking for power on the connector under the seats, but I can't get anything. Also there is non standard electrical coloring so no black or red/yellow wires, so I don't know which one should be the live or ground wires.
It is not a minor thing, I need to adjust the seat for safe driving position.
Any pinout diagram or wiring diagram would help..
Thank you all
2001 ML270 93500 miles
coolant warning light (fixed it)
Coolant leak..
Radio not on (Now fixed)
Lamella sunroof not fully opening (opened twice, small gray plastic bit broke off, not it wont' fully open, erratic operation)
BAS ESP light on (resetting, removing K25 etc, doesn't do anything for it)
Massive water leak, entire floor is soaking wet, even the glove box (!!?).
Driver's lock doesn't turn
Seat controls don't work
Brake switch maybe on the way out
FOBs don't lock/unlock (new batteries) (fixed, one works now, the second starts the car, but won't synch)
Brake discs need replacing all around
Front calipers seized (not sure, is it possible for a caliper to get unstuck when it cools down?)
bonnet struts broken (ordered)
Boot struts broken (now fixed)
running board only on one side
broken front bumper (AMG style ?)
Rust around tailgate handle
Rust under the doors.
faded bonnet
rear bumper off its clips
Thank you all
Coolant leak..
faded bonnet
