DexterML
Hi all, got the diagnostic done at an independent specialist today. Really nice and friendly chaps at Smercs Portsmouth.
They advised me to buy a second hand AAM module (with or without the fusebox, and a new foot well fuse panel and take it from there. I mean I can, but I doubt some of these errors are related to the AAM.. or am I wrong?
Right, some of the errors because the printer was broken and I snapped some photos with my phone of the output on display.
ALSO, the car showed a START ERROR on the dash for the first time to the mechanic. This was with the second key which I am using as the first key seems to get stuck in the barrel.
Most of these errors were stored, so not sure when they actually happened. I was told not to worry too much about them and get a replacement AAM module from ebay as they don't need reprogramming and are a direct swap. Is this true?
AAM All activity module
Communication error no access
EAM extended activity module
B1040 Fault in CAN comms with control unit MR engine control
B1042 Fault in CAN comms with control unit BAS brake assist
B1040 Fault in CAN comms Engine control module
B1041 Fault in CAN comms ESP/ETS
B1088 Fault in CAN comms A1, instrument cluster
B1089 Fault in CAN comms A55, transfer case VG range selection motor
B1396-000 Fault in heating circuit 1 of heater booster
Engine ECU
P1636-008 Electric suction fan open circuit
P1470-032 charge pressure control negative control variation -charge pressure is too high
P1482-001 N14/2 Glow output stage - comms fault
P1354-016 synchronization between crankshaft and camshaft, no camshaft signal
P1354-064 synchronization between crankshaft and camshaft: Plausibility
P1354-064 synchronization between crankshaft and camshaft no crankshaft signal
P1630-016 Drive authorization control unit and drive authorization does not answer
P0703-128 Brake signal plausibility 2
P2201-004 CAN message from control module DAS : Plausibility 1
VG Transfer Case
P1831 Positioner motor or position sensor or power supply is faulty
ETC -electronic transmission control
134 CAN comms with the traction system is sporadically disturbed
147 The gear is sporadically implausible or the transmission slips sporadically.
Engine ECU
VG Transfer Case
