jimjohnstone
- Nov 2, 2016
- 2006 R320 CDI Sport
Just bought 2006 ML350 about a month ago. Really unhappy with the dipped beams, and I've also had a dipped beam warning from day one, although the light is working.
The dips are halogen, but when I remove the bulb holder I found that the yellow wire had been removed completely and was just a loose end in the headlamp shell. There are 2 wires still attached to the bulb holder but one has been spliced (very poorly) to, I presume a live feed from somewhere else.
I'm thinking there is a fault further back in the system, and instead of fixing it properly, they have botched a fix around it.
Until I take the headlamp off I wont be able to check further, but does anyone have any idea where the problem might be if the yellow wire has been bypassed.
