Double the end of the resistor wire over for an improved fit in each plug slot . I used some heat shrink that was about the same width as the plug , which I then doubled back over and put a zip tie around it and the plug if that makes sense.Did you fit one of the plugs from eBay with the resistor inside. I’m just a bit worried the resistor will vibrate out as it is just holding itself in with a bit of heat shrink helping.
