w164 ML faulty door mirror light unit
Bruiser
ml350
Hi -
The drivers side indicator in the mirror stopped working and I got a warning message on the information system.
I replaced the sealed unit but the fault remains. I checked the new part and it works fine on the passenger side. To add to the mystery when I put the new unit back on the drivers side for a second time it all seemed to work. .. until the following morning.
Seems like I have some sort of intermittent wiring fault, any diagnostic tips?
No diagnostics can help there, simply there is broken wire inside the mirror and has to be cut and extended. It moves when mirrors are closed and opened. I took mine to main dealer and they have fixed it on our GL....later versions post 2008 apparently do not have that problem.
If you can waste a few hours with multimeter, enjoy, or pay hour labour to main dealer.
Thanks. Brake wear indicator has just come on so at least I can kill 2 birds with one stone!
