nigel cross
Just started not working either to open or close. tried it on key or handle unlocks and closes tight but no upward or downward poured motion, had to open and close it manually. Any ideas?
Check for leaks through the seals of the fixed rear side windows, or through the tailgate seal. Both are known weak spots.Found the motor under the floor under the spare wheel soaking wet, i will dry it out and see whats occurring
Hi Nigel did you resolve this problem ? about to check the motor/pump in boot myself to see if wet and low on fluid.Does anyone know about how much fluid should be in the hydraulic pump chamber as i cant see any markings, and i suspect its low as it less than 1/2 full.
