Hello all,
My daughters ML280 is suffering from various intermittent faults across most modules. The symptoms are that there is a beep, all instruments including the clock don't work, they will spring back to life almost immediately. Cruise control is inoperative at all times. It is now starting to suffer from a momentary engine cut, although it could be the gearbox I'm feeling.
The battery in the car is about a year old, I've just changed the auxiliary battery and checked the main battery connections when I was in there. I've had the engine bay fuse box out and checked all plugs, relays and fuses were correctly seated. I've taken the central control module out and it 'looks' ok. Under a magnifying light the board doesn't show any signs of corrosion, burning or shorting.
I've attached a photos of the fault codes if anyone can point me in the right direction.
Nigel
Nigel
