W164 ML320 06 no airflow from climate control vents
stewball
A140 2002
Hi guys.
Chris here
New member
I currently drive W164 320 06
Need advice please on no air blowing from climate control vents.
No hot/cold or A/C.
Display and function buttons work fine on dash.
Just no air flow.
Was told it is possibly heater regulator but I can’t seem to find it.
Many thanks guys
The cabin air filter above the blower motor looks fine.
Do you know where the heater motor resistor is and how i access it?cheers Ted
Have you done an actuator re set via the dash controls ? On cars of that era it is sometimes possible . Most likely not to be the fault but easy to do DIY if you car supports it.
Bit like this on a 2006 W203 c class
Hi guys.
Chris here
New member
No hot/cold or A/C.
Just no air flow.
Many thanks guys
Before you try anything drastic check if climate control works when set to auto. Can you hear the blower running and responding to speed setting?
