W164 pre-safe
Graffy77i
Uk
Ml280 cdi w164
I don’t know how to clear this ! Does anyone know how to clear it! My car is an w164 ml280 2006 ! Only fault i have is an parking sensor!
Does the car go.if you can drive it does it go into limp mode.
It used to , but i had to change the gearbox valve body ! Now works fine , the gear box !
Pre-safe uses a number of sensors and activates things like seat belt pre tensioner etc. An out of range sensor value will disable the system. A session on star should indicate what sensor or system is at fault. Important safety feature so worth getting sorted.
Do you know if i can delete it by anyhow?
Don’t think this is an option as this is safety system.
