Hi all, please help! I have a 2015 ML350 (W166) which has the OM642 Diesel engine. Recently I had the engine management sign come on, and been advised my mechanic that the mass air flow sensor (MAF) is showing faults and needs replacing. Annoyingly I had a new Mercedes original MAF fitted in 2021, now they’re retailing at £1000+ new!
My options are either:
1. Have it replaced again with an original so £1000+ and then labour, so expensive
2. I’ve bought a MAF sensor cleaner spray and wonder if this is a part that I can even remove, and clean the sensors?
3 I could buy an used one from eBay, I’ve seen some based in Lithuania about 1/5th of price of a new one, but wary as to if they’d work
4. Fit an aftermarket one which are less than £200 on eBay, but concerned if they actually work or come up with faults on the dashboard.
Any advice greatly received! Thank you
