Can these be retrofitted the the W168 without dismantling the entire vehicleCool
The electrochromic (auto-dimming) RVM was my first retrofit on this car QUOTE]
Full NCB. The issue is the address and being single doesn't help either
Pretty sure it can be - it's only a power supply to it from OCP, the sensor and signal processing is done "in house", if I'm not mistaken.Can these be retrofitted the the W168 without dismantling the entire vehicle
Board and lodging thrown in if you can fit one!He he ... I'd love to (my wife is very keen on the Holiday in Scotland idea too)
I can look at wiring diagrams on WIS, to see what exactly these grey-yellow and pink wires are for, if it's only something like 58d (ambient light) or similar, for the second wire (one of them is obviously just 12V power), then it can be wired correctly. I suppose to make it look perfect, the whole assembly can be fitted. You can then utilise the unused sensor 'eye' for a dashcam or GPS tracker
That's a deal then!Board and lodging thrown in if you can fit one!
I’ve reserched a bit while I was still looking for W168/W169 and found that lower engine running temperature on A150 is usually caused by temperature sensor which is located in the fan housing making a fan to run at higher speeds at all times but worth trying first with thermostat as a cheeper option. It is doable without taking the engine out.Thermostats look cheap enough... but do you need the engine out to change it
Never noticed that on mine.no it works cold, gets dimmer the longer it's on for. Others have reported that it goes dim when the sun's been shining on the dash
Not the whole dash - just the 21 orange LEDs behind the central display* in the instrument cluster, and maybe the dial LEDs (5 each for mph and rpm and 3 each for fuel and oil temp) - mine are 'warm white' - I want pure white.be interested to know how you get on with the LEDs - you doing the whole dash panel?
Wasn't too complicated, but given the age of the car, I'd stock up on some replacement retaining clips: I needed three new ones, which is not too bad, I suppose.I have a bootleg WIS on this computer somewhere but if you have the pages handy to send, would save me hunting. How much of a job was it?
