I've had an emergency front springs replacement, after OSF one split in half.
Unfortunately, Mercedes advised the wrong part number, and when we found out, it was too late to order the right ones, as there were none in the UK - a week or so wait, to get it from Germany...
So, I now have 5 yellow dots springs, instead of 1 dot ones at the front, and they are considerably higher.
I was never too obsessed with lowering the suspension, particularly as this is a small and tall car anyway, and the actual ride quality is better, plus I don't have to worry as much about stupid speed bumps, and suchlike - I'm sure you can see where this is going - I'm not going to replace the new OE front springs, however I want to match the new height at the rear.
Hence, the question: how do I determine which part (how many dots) do I need for the rear?
For what it worth, my own calculations on EPC were spot on - I got 183 points for the front = 1 yellow dot, part number A169 321 1604 (and that's what was on the car). Part given by Mercedes for my chassis was A169 321 2004 (5 dots).
Now, I believe the rear ones are A169 324 0804 (3 yellow dots), as I have 129 points here.
Is there any way to determine how many 'extra' points do I need? The front ones are the top (or bottom if you wish) of the scale for my sports suspension and 18" AMG wheels, shall I go for the same - tallest one for the rear - A169 324 3504 (1 yellow / 1 yellow)?
