What is the cut-off time for the power supply (and the trigger) wires to the CDC in W169?
The CDC is gone, along with the other MOST bits, and I wanted to utilise the conveniently located positive feed - for a multi-camera switch box, and a left mirror camera.
I thought the CDC would be completely powered off after 20 minutes or so, but I have waited longer and both the blue-black, and the red-white wires were still on? Perhaps I should've tested with the glovebox lid closed, but again, I always thought the car goes to low power mode (as in switches off most bits) when no opening / closing of doors, etc for a period of time - so shouldn't really matter the lid was open?
As an alternative solution, I wonder if a standard voltage-sensing DRL controller would work as a cut-off switch, for anything I connect to these wires? Can't see why not, but happy to be corrected
