Hello All,
I have recently acquired a nice 1990 190 carburetor. It has one problem. Occasionally it will cut out or stall when running (usually at speed) and then refuse to re-start for a minute or so.
I have traced the problem to the shut off system. If I disconnect the electrical feed to the shut off valve on the bottom of the carb, the problem never manifests itself. Having established this much, I suspected the shut off relay (labelled "4 Zyl. Kickdown") in the relay box, number A0015457205. So I replaced it with a new old stock one (which did not look very new when it arrived). Still the problem persists.
Maybe my replacement relay is bad, although that seems a bit of a coincidence.
I wonder whether you could tell me what the feeds into the relay are. The terminals are labelled 87, 15, 31, 30, 87k and TD. I have not been able to find a circuit diagram for this car or any meaningful information even on the usually excellent WIS system.
All and any help appreciated.
