MB_mark
Hi All,
I've got a 1991 W201 190E 2.0 Auto, and the magnetic clutch on the radiator cooling fan is engaged all the time, as soon as you turn the key you here a click as it engages....even if you pull the plug off the temperature switch it still remains engaged, the only way to stop it is to either remove the fuse or disconnect it.
It says on the wiring diagram schematic there is "dual contact relay" which energises when the temperature switch closes and I'm sure this relay is causing the problem, but I'll be damned if I can find it! It's not in the main fusebox (there's no aux fuse box ) it's not near the OVP, ECU etc, I've taken the dash lower panels down and it's not in there either.
Has anyone has any ideas where it lives....MB is usually so ordered when it comes to placing relays, but this one is eluding me!
Thanks in advance,
Mark.
Thanks in advance,
Mark.
