blue190
- Mar 12, 2006
- Location
- Crowthorne, Berks
- Birthday present - 94L 190e 2.0 in Black, 88F Volvo 740 auto estate (only for towing!!)
First of all i have just had a new head gasket and head and have bled the cooling system properly following this work. In normal flowing traffic the temp gauge reads between a tiny bit below and a tiny bit above 80 deg. On slowing for congestion, stopping for lights or stop/start traffic the needle rises rapidly to the point where the electromagnetic fan kicks in. Once on the move again the temp soon returns to normal. I replaced the thermostat and housing last year so wouldn't like to think that the problem is that. Since having all the work done the idle is quite lumpy so i am wondering if the ignition timing could be out slightly and causing this overheating, as it once did on a mk2 golf i had following a new cam belt when the ign. timing wasn't reset to suit the timing of a new tight belt. I realise that its a chain on this car but can a similar problem arise?? All suggestions will be gratefully received.
