quenching
I suspect the alternator in my W201 '84 2.0 petrol 190E is not behaving as it should and may need replacing. Now rather than buy one and turn out to be wrong I thought I might try and swap it for the alternator from my W124 '94 E220. Are they a straight swap or is there more to it than that?
The part number on the W201 alternator is 0120489300, a Bosch unit, haven't had a chance to get to the W124 yet but I'm guessing that as they're 10 years apart they're unlikely to have the same part number.
From reading other posts it seems that alternators also have a regulator as a separate plug-in part, is this a better part to start replacing if the voltage output from the alternator seems too low?
Obviously I know very little about alternators
