Hello Everyone.
This is my first post and hope that you can help me solve a weird problem with my indicators.
The indicators will not function with the engine running. They will function with the ignition on and the hazard warning operates the lights okay.
I have checked the fuses under the bonnet near the bulkhead and removed each relay, in turn, from under the cover adjacent to the fusebox. The fault still occured and all other fuctions worked as previously mentioned.
Just to confuse the issue even more if the indicator stalk is set to operate on engine start up then it will for a couple of seconds before 'stuttering' then go off.
I would welcome some help with this and hope I have come to the right place. I would be grateful for all your knowledgeable help.
I use the car in conjunction with my work so hope to sort it out very soon and it is getting too cold to start putting my arm out the window!!
Many Thanks
Paul
Many Thanks
Paul
