Kameel
Good day
My W202 1998 instrument cluster illumination is not working including:
the illumination on the window switches; Gears; and central dash are also not working.
They all went out at the same time.
All bulbs and fuses are okay.
Could the fault be on the Dimmer switch (which has adjustments 3-2-1) or the Main headlight switch?
I doubt its the lighting control relay/module as everything else is working fine
Here is a photo of the Reverse side of my dimmer switch (located next to the Main headlight switch) W202 1998 C180 AUTO
Could the fault be with the Purple and pink tube/wire that connects to the Dimmer switch?
Any advice would be greatly appreciated!
