Whitey
Hi guys
Popped down to MB today to get an airfilter and rather than just pop it in, I decided to clean out the airbox.
I found that the years of oil vapour had perished some noise dampening foam and half of it had been sucked in ! I visually inspected the MAF grille which was clear, not sure about the tea strainer after the throttle - but it wouldn't have made it past the MAF.
The plastic collar holding the foam unclips easily; the foam broke down completely !
I decided to remove the trumpet and recirc tubing to see what effect this would have; the drive to work proved uneventful, with a little more S/C and bypass chuff on lift off.
All this is completely reversable as nothing needed cutting.
I currently get ~280 miles till light on and am hoping a fresh filter may improve things as the old one, though 'clean', had a good coating of oil mist.
I took some photos for your amusement :
