artz
Banned
Symptoms:
MOT and abnormal tyre wear gets me checking out MBClub threads which I find a bit confusing as does Drag Link, Track/Tie Rod Ends what the hell are they?
After finding some good threads here and here I decided it must be the Track Rod End/Ball Joint, however I read the MOT Advice Item again (and checked with tester) which clearly says 'inner Drag link end ball joint' so my problem is not as simple as a replacement Track/Tie Rod End and after reading a few other posts around the net, replacing just these alone doesn't seem to work too often!
After a bit more research I found this photo and diagram below which I found useful when trying to work out this seemingly common problem.
You can see the outer and inner ball joints and in between them another joint which I hope someone can name (thrust arm linkage perhaps?). Number 4 is the steering damper by the way, which looks worth/necessary to replace at the same time.
So after many hours of research I believe (please tell me otherwise) that only the outer track/tie rod ends can be bought separately/cheaply and presumably why everyone makes the mistake of fitting them first.
My guess is that these tie rod ends probably need replacing (in isolation) after a big thump or kerbing rather than after a slow degeneration from constant wear and tear of 100,000-ish miles.
So in conclusion, rather than 'jump in' I'm going to wait until the knocking or abnormal tyre wear are a real problem and then change the whole Drag Link - Tie/Track Rod Assembly which as far as a novice like me is concerned is going to be both difficult to do and expensive with the tracking then/also having to be done by a pro.
I have found a steering rack/drag link/tie rod assembly here (Ebay) for £78.50 delivered but obviously check if its the correct part for your own car.
Lastly I would really appreciate help/posts/comments here and in particular how do you do the job itself - is it as difficult as I think its going to be?
A good step by step guide would be very cool here but when I do get around to doing this job I will definitely film my efforts/f**k up's and post it here.
Thanks in advance and I hope this helps others with the same problem... and budget!
Teach-Me-Auto...A nice video of doing this job on a Dodge Ram, different to a Merc but it certainly gives a good overview.
- Advice Item on MOT says O/S inner Drag link end ball joint has slight play.
- O/S front tyre worn through to material but only on the inside (3"-4") so not actually visible unless regularly checked.
- Slight knocking from front wheels when going over rough roads, pot holes etc.
