jwhaslam1990
Hi all,
You may have had people ask this sort of thing before, I've done alot of trawling through the internet and it seems to come up alot and everyone has a different opinion.
Basically I have a W202 98 C200 that has the 38 pin diagnostic plug. Naturally seeing as I had the obd2 bluetooth jobby for other cars to read Android torque, I thought I would look to see if I could get it to work on the Merc. I purchased a 38 pin male merc plug to 16 pin female obd2 adaptor off of the bay.
Internally the cable contains the following connections...
38 pin end ------- 16 pin end
1 ------- 4+5 signal ground
3 ------- 16 battery power
4 ------- 7 K line
I tried this with no joy , so looked on the internets again which suggested that to read the ISO 9141 protocol I would need to read the L line of the ecu as well so i cobbled a connection between pin 15 of the 38 pin to pin 15 of the obd connector. Alas, this also did not work.
I have only tried to use this with an ELM327 v1.5 bluetooth reader with Android torque on s3 and scantool on laptop with vista but nothing seems to work, I get power to the scanner but can't connect to the ECU . Any one have any advice or an opinion on anything I've done?
Any help would be greatly appreciated many thanks.
James
4 ------- 7 K line
James
