Dave Bailey
Hi All,
Does anybody know at what ambient air temperature the A/C is supposed to start working at? Although the outside temperatures aren't that warm at the moment (12 - 14c), I'm pretty sure that the A/C should work anyway. I've read on other threads that the compressor should run all the time, irrespective of outside temperature. My compressor doesn't seem to cut in, so I have convinced myself that there is a fault. Is there a fairly easy way to check the system? It would be good to verify the problem before I call an A/C specialist.
Thanks in advance,
Dave
Thanks in advance,
Dave
