funkymonkey
- Mar 19, 2010
Morning folks!
I've scoured the forums, but not found anyone with symptoms like mine, so I'm putting it out there hopefully someone may be able to help!
Car is a 2000 W202 C230K with ~115k on the clock. Every so often (maybe once in 50 miles) while driving along the traction control light in the centre of the speedo flashes up. Most of the time it just flashes and the car doesn't react to anything, its just a flashing light. However less often, the ASR kicks in and the front left wheel reacts as if it is loosing traction (an ABS style braking and associated pull to the left). After a couple of seconds it stops and all returns to normal. The ABS event nearly always happens when driving in a straight line.
The weird thing is, I have no warning lights at all, only the traction control light when it is actually happening. What worries me however is that the classic BAS / ASR warning light never illuminates, not even when turning the ignition on whaen all dash lights normally come on. Is this normal? Has someone disabled the light to hide the problem?
HELP!!!
cherrs guys!
HELP!!!
cherrs guys!
