LittleRestraint
- Feb 22, 2014
- C200
Just a quick one...
Is it considered safe to to put the car on four axle stands, one under each rubber jack point?
I have two trolley jacks and a total of 8 axle stands kicking about. I just want to check my method seems ok on the W202..
1. Jack up the front using the cross member type part just in front of the steering damper
2. Jack up the back using the diff casing
3. Axle stands on all four rubber jack pads
Would it be worth putting anther couple of stands somewhere for added safety?
Am I best to use a bit of wood between the jack saddle and the car when lifting?
Thanks, always like to check these things the first time I get an unfamiliar car off the ground!
