Ds24215605
- Jan 15, 2017
- c230 1997
Good morning,
C230 2.4 Sport Automatic Petrol W202
I will try and be specific;
I have had a new battery and alternator fitted as expected the alternator was goosed.
After it was fitted i noticed that the Battery/Alternator warning bulb was not illuminating. (this could have not been illuminating prior to me renewing the battery and alternator hence the issue of flat battery!)
After a lot of fault finding by the Automobile Association it was found that the Alternator was not charging the battery but when it provided with a separate power source to provide excitation it was working fine.
He traced the fault to be between the D (Small) connection on the alternator and the dash light bulb. Apparently if the bulb is not working correctly it does not complete the circuit and excite the alternator on start up.
Action i have taken.
Removed the dash and fitted new bulbs (Correct voltage etc....)
Cleaned all connections.
The car starts fine but the battery / alternator bulb still doesn't come on or off? and the alternator is still not charging the battery?
Is there something else i am missing a fuse or something simple i have overlooked? I have checked all my fuses and they all seem to be ok.
any help appreciated,
Cheers
Derek
Cheers
Derek
