stuboy
Ok i'm guessing somewhere near the back of the dash?
The problem is my LH headlight is not working, done so far:-
1) checked fuses OK
2) checked volts at lamp connector removed from the lights, 8.5v this would point to a dodgy joint somewhere. According to my trusty Heynes manual the wires go to the Bulb failure control unit but doesn't say where it is! Teapot and chocolate springs to mind!
3) Took fuse panel out and traced wires back from lamp and they do seem to disappear into the bottom of the dash area.
4) Rain stops play until tomorrow so any suggestions or help would be much appreciated, i got to removing the bottom under the steering wheel.
Regards
Stuart
1) checked fuses OK
Regards
Stuart
