design guru
- Feb 28, 2004
- Location
- Hampshire
- 2001 W220 Mercedes S320cdi & 2001 W208 CLK230K (SORN since 2008)
My cousin is stuck in London as he can't get his car to start. He needs a solution for the problem below. He has basic recovery which was given free with a certain bank account upgrade. The Green Flag repairman said the ignition barrel needs replacing.
Spoken to a local garage who said the can only replace the barrel if its in their garage. The problem is the car can't be towed because its stuck in park. Can the gear be changed to neutral so the car can be towed. At present the Recovery and the garage are saying the car needs to be lifted at a cost of £150-200.
The car was parked up and when he went to start it the key turned to the first position but after that it just spun when he tried to click into position 2 so the car can't be started. Its a flip out key model, not the electronic key.
If there is no way then he will join a different recovery and get the full package and get them to move it. His current recovery does not allow him to upgrade because he already called them out.
