I've been looking at a well-maintained W202 1998 C Class that's for sale.
I thought I had checked the obvious, but I missed the condition of the OSF jacking point .
It has rusted badly, and has clearly then been used to jack the car. The rubber pad has been pushed into the sill, with lots of flaky rust where it should be attached to the sill. An immediate reason for MOT failure, I believe.
The rubber drain grommet is still there - but is rattling around inside the sill, as the mounting hole has rusted as well. Looking at the jacking tube behind the plastic sill cover you wouldn't suspect it was so bad.
So... options and opinions please...
I've done some online searching, but can't find a lot with regards to replacement sill parts.
I'll phone main dealer tomorrow for outer sill prices, plus jacking tube replacement.
Has anyone been able to source 3rd party sill parts for W202?
Andy27168's thread on the sill repairs to his AMG makes great but scary reading, but the car I'm looking at is a mere C Class. I have to be realistic on repair costs vs value of the car.
Assuming I can source a sill, then do any of you have any idea of the labour time to cut out the old and weld in the new? I can deal with filling and painting (it's mostly hidden by the sill trim).
Andy27168's thread showed the wing and doors being removed, so I can see this adding a few hours of labour if this is necessary.
