Hi guys, my issue is that I can't get my W202 out of 'Park'. Before posting I did a general search and one of the ways around this problem as a temp solution, is to press down some sort of switch or button with a screw driver / chop stick / whatever is handy, but that doesn't seem to have solved anything.
Here is where I am sticking the screwdriver into: :fail
Can it be the break light switch under the pedal or is it likely to be the small plastic gear selector level / hook thing inside the gear selector assembly that's cracked and disintegrated?
(I found this page over in the US about the plastic gear selector and the stuck in park related issues: http://fixeurotransmission.com/blog/mercedes-benz-shifter-stuck-park-wont-move/ )
Any ideas on next steps guys?
