I've been reading all the ATF change threads and I recon I'm reasonably clued up on what I need to do. The hardest bit for me I think will be the fact that I can't get the car very high off the ground and I'll have to do it all lying down on the driveway....
However, I do have one question.
When draining the torque converter on the V6 models, do I need to remove the section of exhaust pipe from the LHS bank of cylinders to the cats?
It looks like removing the plug could be tricky with the pipe in the way...?
Cheers, Chris
Cheers, Chris
