Seank791
- Feb 18, 2016
- W202 C250td
Hi guys, my car has developed a fault In relation to the gearbox, it's now very stiff to get into 1st 2nd and reverse gears, there are no crunches whines or noises of any sort, however it requires force to get the car into any of these gears, the remainder of the box 3rd 4th and 5th are perfectly normal and very easy to engage as normal. This has been ongoing now for roughly 3 days. Trying to get out of 1st 2nd and reverse also requires force to return to neutral, and I have noticed that it can get stuck coming out of reverse between 1st and 2nd needing force again to return to the neutral position.
However tonight it's now starting to stick in 2nd gear, I can try to engage any other gear but the car refuses to engage only staying in second if I release the Clutch, regardless of where I have positioned the gear lever.
I'm assuming this could be an issue in relation to the gear selector or gear linkage, possibly also gear oil but my mechanical knowledge isn't brilliant and I'm slowly learning from faults I find as I go, alongside having an excellent friend who helps me do everything I'm incapable off
If anybody could offer an insight this would be greatly appreciated, I've seen a few threads about manual gearbox issues on Mercs but nothing mentioning the diesel gearbox, I've tried to explain the fault as best I can at current. Thanks in advance folks.
