w202 c36 srs light
horgantrevor
w202 c43 & w210 E220 CDI estate w219 W221
hi i had the car tested today and the srs light fault came up i did not have it going in
when you turn on the engine the light comes on blinks a sec , and then stays on for about 2 min and stays off then
the last owner jumped the car a few times as he had it in storage and also he had a dead mans switch fitted that he used all the time
would this do the damage the seats are electric and i cant find any loose cables on the passenger seat as this usually can cause it
do you think its just a reset job
Dead mans switch? Whats that?
kill switch battery cut off
Read the fault codes firstly and then post back on the result
getting it done tomorrow i will
